P1259 code - Help!!! , stuck , where to go next.?..
Old May 31, 2017 | 10:06 AM
Roxie's Avatar
Default P1259 code - Help!!! , stuck , where to go next.?..
performed oil flush, Replaced Vtec solenoid.
Checked oil pressure at oil switch, has 15 psi at idle and 70 psi at 3000 rpm
Checked the oil pressure at the pressure switch on Vtec valve, had no oil pressure at idle and 25 to 30 psi at 3000 rpm
These readings were done at hot oil temp. Also when watching the pressure comes up slow on test guage
When cold works perfect. When cold outside low 50's it works for a long time before it stops working. When watching the scan tool you see it gets signal at solenoid but it's not enough pressure quick enough to get solenoid to work
2002 Accord 2.3 4cyl
Old May 31, 2017 | 10:22 AM
holmesnmanny's Avatar
Default Re: P1259 code - Help!!! , stuck , where to go next.?..
Pull the solenoid and check the filter that it attaches to at the head to see if it's clogged up.
Old Jun 1, 2017 | 03:07 AM
Roxie's Avatar
Checked the solenoid filter when solenoid was changed. Not clogged
Old Jun 1, 2017 | 02:54 PM
check for upward dents in the oil pan that would prevent good oil pressure by restricting the oil pickup
Old Jun 1, 2017 | 04:01 PM
Roxie's Avatar
Didn't notice any upward dents in oil pan, will recheck. Have pressure at the switch but looses pressure at the heads.
Thinking the problem might be with the cylinder head
Jimster480
Feb 25, 2011 08:16 AM
aznd87
Nov 6, 2006 01:32 PM
scarecrow
Mar 7, 2005 10:26 AM
xXx Justin xXx
Aug 1, 2003 12:19 PM
r7
Aug 19, 2002 06:34 AM
