Low Oil Pressure
Low Oil Pressure
So ya I have had low oil pressure now for about a week. Usually I would have high pressure when I turned it on and eventually it would go down to about 1PSI per 100 RPM. Which is fine. But now I turn it on and its at about 50PSI @ 1000 and once it warms up it settles to LOW AS HELL. With it being @ 20PSI @ 3000-3300RPM. The thing is that when it is low like that, it can go to 5PSI @ 1500RPM (my usual idle, yes its high, I have it like that for a reason). But then if I step on it, it will be @ 65PSI @ 7K RPM, which is pretty normal. I have no idea what is causing this ****, and I need to fix it before I blow it.
And yes it has plenty of oil, actually right now it has about 1/4th of a quart MORE than full, and it didnt help the pressure at all.
The Grumpiest
Re: Low Oil Pressure
That happened to me ONCE last year. Oil pressure never seemed to get up to where it was supposed to be. I panicked and added more oil and slightly overfilled it. After I drained it I have not had an issue since. I suspect it was the gauge acting up now that I think about it (don't buy cheap Sunpro gauges folks). I usually get about 50PSI @ 3krpm and about 25PSI @ 2.5rpm at idle with a ported oil pump though.
steveharrmr23
08-07-2008 10:52 AM
