bolts for engine on stand?
Old May 30, 2017 | 04:15 AM
K-G's Avatar
K-G
Default bolts for engine on stand?
hi I'm having a simple problem and I cant find accurate info.
I picked up a engine Stand & lift for 100$. brand new from a friend.
Now, I'm trying to put my b20 on the stand.
I do not have any bolts that will fit into the block from the stand.
I also read I will only use 3 of the 4 arms? is this accurate?
What would the proper length & size bolts needed?
Old May 30, 2017 | 11:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: bolts for engine on stand?
I used the transmission case bolts or some long bolts that fit through the casing holes if they weren't threaded with a respective nut, used all 4 arms and I had to go pick up some steel nuts that were bigger than the bolts to use as spacers so the engine wasn't loose on the stand.
You can see some of it in my picture below:
Old May 30, 2017 | 11:31 AM
K-G's Avatar
K-G
Attachment 431817
thanks for the reply. The picture helps.
unfortuantely the motor didn't come with a tranny so I don't have any bolts to test.
Guess I'll have to go with trial and error in this case. Thabks
Old May 30, 2017 | 11:50 AM
NVturbo's Avatar
O.G. triple O.G.
8mm x 40 bolts. Wouldn't hurt to get longer bolts and washers.
Old May 30, 2017 | 11:55 AM
K-G's Avatar
K-G
Perfect. Thanks a lot bro. I appreciate it !!
Old May 30, 2017 | 12:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I don't remember, is thread pitch 1.25 (oddball Honda special) or standard 1.5?
Old May 31, 2017 | 03:15 AM
NVturbo's Avatar
O.G. triple O.G.
my bad guys.. Double-checked my notes and the correct bolt is M12x1.25 50mm
Old May 31, 2017 | 06:04 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Those will be a bitch to find.
1.25 thread pitch is made specifically for Honda and even the fastener companies don't carry that irregular thread pitch.
I did find that M10 x 1.5 will fit into the M12x1.25 threading well and hold decently.
These same bolts and nuts are used for the torque mounts (just short length versions) on the 92-95 civics and when I went to change to the aluminum mounts the original bolts did not fit and I had to find a solution.
Your best bet though is to go to the scrap yard and pull some tranny bolts from some civics. That way you get the M12 x 1.25 that fit perfectly.
Old May 31, 2017 | 08:21 AM
K-G's Avatar
K-G
Icon6 Re: bolts for engine on stand?
thanks tom
Old May 31, 2017 | 08:26 AM
K-G's Avatar
K-G
thanks for the correction
Old Jun 1, 2017 | 03:06 AM
NVturbo's Avatar
O.G. triple O.G.
Supply houses that stock metric bolts should have them. There are 3 places in my area that carry them. Yeah, for the most part, it's either Honda (online or dealership), salvage yard or part-outs.
Old Jun 1, 2017 | 07:54 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That's funny, I'm in Canada which is all metric but the 1.25 thread pitch is not common and even Fastenal didn't carry any 1.25 thread pitch bolts.
For standard metric it's 1.0 and 1.5.
Maybe next time I'm in need, we can work out a deal.
Old Jun 1, 2017 | 08:08 AM
jdblock's Avatar
Crazy. I can go down the street and get 1.25 threads, in California.
Old Jun 1, 2017 | 08:10 AM
NVturbo's Avatar
O.G. triple O.G.
TomCat....
sounds like a plan.
Last time I was at that shop, I needed 4 bolts. He had them in stock in a big *** cardboard box. The old guy just told me I could have it, FREE. lol
Old Jun 1, 2017 | 08:52 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It could also be from the style of bolt I was looking for. I needed alan head bolts not regular hex flange head.
Old Jun 1, 2017 | 09:29 AM
MADMKIII's Avatar
McMaster Carr has them.
http://www.mcmaster.com/#standard-he...crews/=17vr5op
Old Jun 1, 2017 | 11:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by MADMKIII
That's awesome, I wonder if they will ship to Canada. They even have the M12 x 1.25 Alan head bolts in Grade 12.9!
B_Swapped93
Sep 10, 2014 04:26 PM
jcarothers
Jun 2, 2004 09:59 PM
civicmatt
Nov 14, 2002 11:13 AM
B96v6
May 31, 2002 05:25 PM
