high beams stopped working
Old May 28, 2017 | 07:49 AM
brokefrustrated's Avatar
Default high beams stopped working
97 Accord Ex 2.2 vtec 234000 miles. well maintained no high beams . Replaced Headlight Relay in engine control Panel, also replaced Combo turn signal switch on steering Column. Also swapped out Dimmer relay with 2 different relays I got from e-bay. Is there one fuse that if blown would kill both high beams @ same time. also without lights on pull dimmer switch and low beams come on with blue high beam indicator light. In fact, High beam indicator has worked perfectly whole time when lights on and switching to high beam, just no high Beams. Could some Corrosion showing up in ground Batt Cable cause this Mystery?
Old May 29, 2017 | 03:46 AM
jollyhonda's Avatar
Default Re: high beams stopped working
Have you verified that the bulbs are both good?
Old May 29, 2017 | 08:15 AM
2001GSRSC's Avatar
5 Year Member
The relay?
Speedy5966
Jun 8, 2019 10:51 AM
TeggyTitan831
Nov 16, 2018 05:27 PM
rezzarect
Jul 28, 2007 08:22 AM
hookem51
Honda Civic (2001 - 2005)
May 4, 2007 06:25 PM
c_buz
Dec 9, 2004 07:10 AM
