03 Accord stuck on low beams
Hi! Newly acquired 03 Accord. When I switch between high and low beams, the high beam indicator on the dash comes on in high beam, but the lights stay on low beam. There is no change at all in the lights. Also, with the ignition and lights off, if you pull back on the dimmer switch, it's the low beams that come on. I figure it's the switch, because the low beams stay on when you go to high beams. If the low beams went out, but I had no high beams, I'd figure it was both high beam bulbs. I just don't want to go to the work and expense of replacing the switch, and have it not fix the problem.
Thanks!
Thanks!
dlric
17
04-15-2016 03:36 PM
rezzarect
07-28-2007 08:22 AM
