B18C1 Swap Idle issue
Old May 27, 2017 | 07:54 PM
Verkmiester's Avatar
Default B18C1 Swap Idle issue
So im completely done my B18C1 OBD2a swap (96 EK Hatch), fixed every issue except 1 at this point. When i start the car it idles at 1500 and slowly climbs to 2000ish. Once its warm if i turn it off and on again it will idle at 1000. Then while i drive around if i press the clutch in it will "idle" at 1500-2000 until i stop, then it will idle at 1000 again (if its warmed up).
  1. Car has 0 CEL's
  2. Ive tried 2 IACV's one in which i cleaned very well
  3. Ive wired the IACV directly to the ECU
  4. Ive multi-meter tested the TPS and its good.
  5. Ive sprayed brake cleaner in search of a vacuum leak
  6. when i put my finger over the hole in the TB partially i can get the idle down to normal, if i cover the hole completely the car will die out.
  7. Ive bled the coolant system several times
  8. Motor does not have a FITV
Wondering if anyone can think of something else i can check, im running out of ideas :/
Old Aug 8, 2017 | 01:32 PM
Jdmswap98's Avatar
Default Re: B18C1 Swap Idle issue
  1. Car has 0 CEL's
check for vacuum leak in break booster
Old Aug 8, 2017 | 01:58 PM
2x0's Avatar
2x0
10 Year Member
^ I second that it's sounding like a vac leak. I've always just used smoke to find em.
Good luck.
rwcdrums
Aug 1, 2007 05:59 AM
DenzComp
Jul 3, 2007 05:00 PM
CivicSwapper
Nov 10, 2006 07:59 AM
6969crx6969
Feb 29, 2004 02:59 PM
