88 Civic hatch smoking and throttle issue
Old May 25, 2017 | 06:54 PM
ceaton36's Avatar
Default 88 Civic hatch smoking and throttle issue
so i didnt see this in here. so i have a 88 civic hatch with a d15b1 and if i am going down a hill and using like compression breaking i am getting oil out of the exhaust... i put a PCV on it and it seemed to help alil but still doing it i put the PCV on a couple days ago. could be oil still in the motor slowly working its way out or could there be something else? and after my car warms up and i give it throttle it wants to bog down almost killing itself but then picks up is that just the dual point injection or again more issues i picked the car up for a grand and already dumped prolly 350 - 400 into it so anything helps... like i said in my intro i am new to the Honda scene and just want to make sure i am not over looking something easy
Old May 27, 2017 | 07:34 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 88 Civic hatch smoking and throttle issue
This could be a few things. Best to start off with the PCV and you already did that.
Sounds like I could be internal issues - broken valve, worn piston rings, bad valve stem seals
Pulling the spark plugs might show a specific cylinder that might be causing issues.
A quick comprsssion check can help see if you have anything significantly bad.
If that doesn't show anything, then an endoscope might show if there is a lot of wear on the cylinder walls.
Do you notice smoke while cruising?
If you idle at a stop light for a while, do you notice smoke and then not so much while cruising?
Old May 27, 2017 | 07:44 PM
ceaton36's Avatar
See thats the thing only going down hill...compression should 175 175 180 and 200 clylinder 1 at 200 made me nervous but its still within 25%...and no doesnt smoke any other time...the car runs like a dream no valve tick no knocks nothing besides the stutter on accel
Old May 29, 2017 | 12:16 PM
Slade Exulis's Avatar
Check your mechanical timing. It probably doesn't have anything to do with the oil issue but if your stumbling/misfiring it's good to check it.
Are your spark plugs oilly/really dirty? Is there any oil on the end of the spark plug boots?
Old May 29, 2017 | 12:21 PM
ceaton36's Avatar
Very little on the boots all plugs are clean a couple have oil on threads but thats not to worry i would love to check any kind of timing on my car but for some reason the removed all,trace to,check timing
Old May 30, 2017 | 02:23 PM
ceaton36's Avatar
anything i am at a loss...i am so confused unless valve seals only happen some times or when oil pressure is built but i dont know
Old May 31, 2017 | 10:23 AM
4drEF's Avatar
Keyboard Humorist
Valve seals typically smoke when you idling for a while.
Rings will typically make smoke when you decelerate.
Compression looks ok, but it's not great.
I would do a leakdown test to try to pinpoint the problem.
If that doesn't tell you anything then it's time to pull the head and have a good look inside.
Old May 31, 2017 | 10:52 AM
ceaton36's Avatar
So down hill off throttle in lets say 4th the motor is slowing down and smoking the give it gas and blows a big cloud out prolly rings...but it doesnt do it on flate ground like going to a stop light like using compression braking doesnt smoke Thats y i am kinda lost
Old May 31, 2017 | 12:09 PM
ceaton36's Avatar
I think i made up my mind i think im going to ls swap my hatch and do a mild build i wanted a b20 but alil out of my price range im not trying race just a car to have fun with
Old Jul 1, 2017 | 03:24 PM
ceaton36's Avatar
So i the ls fell through i think i am gonna go with the mini me swap...but my concern is the compression of of cylinders is there another set of pistons i can drop in. I have the d15b1 block wich is the same as the b2 i was told i should be looking at like 120 or to wheels for horsepower any help would be nice and yes i know a ls or gsr would be better but out of my price range
socialistic
20
Jul 31, 2011 10:47 AM
jtrig
Feb 21, 2011 05:55 PM
eg:R
May 12, 2009 11:48 AM
HybridBB6
May 14, 2007 02:36 PM
Yankee
Oct 27, 2004 07:23 AM
