Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Excesive fuel consumption 9MPG, civic 07
Old May 21, 2017 | 09:14 AM
Gabsho's Avatar
Icon4 Excesive fuel consumption 9MPG, civic 07
Hello everyone.
I have a stock 2007 Civic and currently it does not give me more than 9 miles per gallon. I make short trips about 5 miles in the city, from the house to the office. There is no check light, I scanned it and do not have any code.
The only symptoms I have are the high fuel consumption, the car vibrates a little when I'm stopped at some traffic light with the air put on and I noticed a little kick when the car is cold and I put reverse. I have gone to two dealerships and I am told that as there is no code in the scanner can not do anything.
really need some help.
pd. Sorry for the bad english.
Old May 21, 2017 | 05:55 PM
holmesnmanny's Avatar
Default Re: Excesive fuel consumption 9MPG, civic 07
the only way you're getting only 9mpg's is if you have a massive fuel leak
Old May 22, 2017 | 03:29 AM
Gabsho's Avatar
there is a way to check that posibility?
Old May 22, 2017 | 06:41 AM
Ryanthegreat1's Avatar
You are only getting ~100 miles on a tank of gas?
Old May 22, 2017 | 06:53 AM
Gabsho's Avatar
I Just use half of thank and refill, with that I just get about 50 miles.. completely insane! There is no fuel on the garage floor, no gas smell.. I do't think a bad O2 Sensor can drop the fuel economy to this level.
Old May 22, 2017 | 08:53 AM
Sounds more like someone is stealing your fuel.
Old May 22, 2017 | 09:13 AM
Gabsho's Avatar
Icon6 Re: Excesive fuel consumption 9MPG, civic 07
Already check that, not the case.
Old May 22, 2017 | 10:58 AM
97emsedan's Avatar
Was the proper maintenance completed at the intervals? Have you changed your plugs? Engine air filter? Was the valve lash adjusted when required? Tire pressure, driving style, stop ad go traffic. They all add up. If you stomp on the gas from a dead stop, accelerate erratically, your fuel economy will go down.
Old May 22, 2017 | 11:27 AM
Gabsho's Avatar
Hi.
Tire pressure is 32 psi
Plugs was checked and suppose to be OK (not changed)
Al most all days I just drive from home to the office (about 2 mile trip, about 5 minutes)
Drive like a scary oldman
Air filter looks clean, change it about 18 months ago. (can be fuel filter?)
Go to the dealer 2 time in the last month and they says that there is no need to change the oil (I have about 18 month with the same oil but just 800 miles in that time)
Valve lash? Never do that, don't even know what is that. (on youtube now checking what it is)
The car has about 89,200 miles on it, don't now if that is important.
k3ntegra
Dec 20, 2014 05:16 AM
forevermemorabl
Oct 28, 2013 04:54 PM
drkns
Jul 21, 2006 09:11 PM
vw_ev
Dec 15, 2002 03:58 AM
Russ59
Jan 27, 2002 11:26 AM
