No start 94 Honda Civic
Old May 21, 2017 | 08:55 AM
levi4396's Avatar
Default No start 94 Honda Civic
hey guys, i'm having a issue with my 94 EX Civic. The car will not start at all anymore. on 5/20 I replaced the spark plug wires and pulled the plugs to check them. my old man put Bosch plugs in when i told him to get NGK. anyways i put them back in after finding carbon build up on the bottom and the tip was white . i got in and cranked it but it wasn't starting and figured out i had a few wires out of place. got it started and it was rougher idle than before. (Had a low idle before wires but wasn't too bad) 5/20 I went to Orilleys and got a cap, rotor, and coil. basically the same issue. 5/21 i went and bought NGK plugs and installed them. we cleaned the throttle body while it was on the car. we cleaned out the air intake and checked the filter. I started the car and my old man was listening and the dizzy made a noise and the car died and has no spark. we got the test light out and the negative and positive post on the coil are getting positive power. the whole engine minus the valve cover is getting a positive charge. when we tap the negative lead on the negative terminal there is a click from somewhere around the air intake manifold. but the car wont spark at all, just cranks. any help is appreciated.
Billitary
Feb 16, 2012 11:46 PM
micah13x
11
Apr 14, 2011 03:09 PM
thecruzs2007@yahoo.com
Sep 22, 2009 07:41 PM
x_tc-Dae
Oct 7, 2004 01:07 PM
