Suspension & Brakes Theory, alignment, spring rates....
Wilwood brakes dont line up!!
Old May 20, 2017 | 07:52 AM
Michael Masters's Avatar
Default Wilwood brakes dont line up!!
this is week 3 trying to figure this out, and I will start by saying I'm a mechanic so installation error isn't what happened, but basically when I first installed them, when I would torque the rotor to the hub the rotor was pressed up against the pad so much that I couldn't even spin the wheel, after tons of phone calls of them telling me that they have never heard of this issue I bought a shim kit and tried to shim the caliper. I got it a little better to where I can drive it but it's bullshut because nowhere in the instructions does it say I need to shim ****... but now basically the caliper doesn't sit right in raltion to the rotor so the pads don't fully contact
Old May 20, 2017 | 07:55 AM
Default Re: Wilwood brakes dont line up!!
And I tried milling down the rotors like crazy trying to get them to fit, so I'll be buying new rotors either way
Old May 20, 2017 | 08:02 AM
Hamster65's Avatar
Check to make sure you've got good travel on your guide pins. One or both of them sticking can cause this issue. It wasn't a Honda but, I had this happen on another vehicle. One of the guide pins was stuck, which didn't allow the caliper to "free float" the way it's supposed to.
Old May 20, 2017 | 08:09 AM
These are solid mounted calipers!! That's why this is so frustrating
Justin Meiring
Oct 14, 2014 08:41 AM
zero708970
Nov 10, 2008 07:33 PM
Chief Brody
Jun 12, 2004 10:48 AM
DAguyLS
19
Apr 26, 2004 03:16 PM
fso_BamBam
Jun 16, 2001 11:08 AM
