obd2a ecu, odba interior loom, obd2b engine loom problem
Old May 19, 2017 | 08:11 AM
Keith 000's Avatar
Default obd2a ecu, odba interior loom, obd2b engine loom problem
Hey lads need a hand here with a build I'm doing on a ek civic. I have a obd2a interior loom and a obd2a spoon ecu that I would like to put with my obd2b engine and loom is it possible to get a harness for this if so what type do I need. Any help appreciated
Old May 21, 2017 | 03:58 AM
80%downtime's Avatar
Default Re: obd2a ecu, odba interior loom, obd2b engine loom problem
Look for ffstech's pictures of OBD2A and OBD2B pinouts. Put the pins on your OBD2B connectors where they correspond to the OBD2A pins and you'll be fine. Otherwise, buy a rywire harness, splice the proper wires and get it over with.
Old May 21, 2017 | 08:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That sounds like a lot of work... how about sourcing a '96-98 OBD-2A engine harness, install it on your engine, make any minor wiring changes necessary (distributor plug and maybe IACV depending on harness version) and simply plug it in inside the cabin.
RobEJ
Engine Management and Tuning
Aug 1, 2016 01:35 PM
BbOi0420
Nov 28, 2014 10:40 AM
nycpatron
Feb 25, 2010 07:53 PM
Zero Signal
Dec 9, 2008 12:04 AM
xyzalvarez
Mar 20, 2005 11:49 AM
