1999 Acura Integra speedometer and odometer not working
I have a 1999 acura integra the speedometer and odometer don't work. I have replaced the VSS twice with brand new parts and still no change. I have changed instrument cluster three times and still not working. oh and by the way it tis manual transmission. I also checked the wheel on end of piece that spins in transmission and it is fine. What would cause this problem? I also tried to hook a drill up to speed sensor and spin it with sensor plugged in and key on but no change.
double check with a multimeter that the vss is getting power and putting out the pulsed signal. Otherwise, maybe the cluster is shot or the wiring is incorrect.
superslowcrx91
May 8, 2013 08:10 PM
