Trans suddenly stopped engaging
Old May 13, 2017 | 07:06 PM
jspinelli8's Avatar
Default Trans suddenly stopped engaging
My 2000 civic ex coupe has never had its clutch/pressure plate/flywheel changed and everything worked fine until i started it today and the car won't go into gear at all. You can hear the gears changing when you row through them with the clutch depressed but i don't know why it suddenly stopped working altogether when there were no problems before. Anyone know what specifically could be the problem?
Old May 13, 2017 | 08:50 PM
Chance EG's Avatar
Default Re: Trans suddenly stopped engaging
So if you put the car in first gear and rev it, it acts like it's in neutral?
Not really sure what it could be right now, but I'd start by making sure your clutch reservoir fluid is fine and that when you depress the clutch pedal that the fork is moving properly. Maybe the pressure plate isn't engaging correctly?
Old May 13, 2017 | 09:39 PM
jspinelli8's Avatar
Exactly its like its permanently in neutral even though i can hear the gears change as i row through them
thanks i'll be sure to go through those things
Old May 14, 2017 | 04:40 AM
mk378's Avatar
Does the speedometer go up when you put it in gear and try to move? If it does, that means the clutch and transmission are working; it's an axle problem.
Old May 14, 2017 | 06:12 AM
Chance EG's Avatar
Good call
Old May 14, 2017 | 02:24 PM
jspinelli8's Avatar
Found out that the problem wasn't with the transmission, jackshaft snapped.
fminusmic
14
Feb 1, 2022 05:07 PM
DC2R96
Mar 21, 2011 07:29 PM
02_Si_FTW
Jul 21, 2008 01:57 AM
EG_LS
15
Sep 3, 2007 06:01 PM
chocolatesk8er10
Jul 25, 2007 11:24 AM
