Transmission problems
Old Mar 18, 2011 | 09:57 AM
DC2R96's Avatar
Default Transmission problems
No leaks, clutch feels strong doesn't get stuck to the floor, when I let the clutch out in first gear the car surges real bad feels like the clutch is slipping like ridiculously .. it is VERY hard to get the car in a different gear while moving but it slides in easy when stopped ... The car also shakes a lot in reverse not smooth at all .. I'm hoping it's just the clutch and the transmission didn't fail on me some how .. The weird thing is the motor is a JDM b18cR that I just got going about a week ago, it was running just fine when I got it going no problems at all .. Just started doing this last night I noticed first gear was real jerky when I let the clutch out, then couldn't get it into any other gear while moving .. Could low transmission fluid cause this ??
Old Mar 18, 2011 | 12:47 PM
Aquafina's Avatar
Default Re: Transmission problems
What did the clutch, pressure plate, flywheel, and t/o bearing look like when you put them in? What trans fluid?
Old Mar 18, 2011 | 06:05 PM
jawls's Avatar
x2.
Old Mar 21, 2011 | 03:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
clutch disc failure..
Old Mar 21, 2011 | 07:25 PM
DC2R96's Avatar
yea .. but it works at idle .. I can go through the gears with the clutch pressed down but when the tranny is moving it doesn't work .. I was thinking pressure plate
Old Mar 21, 2011 | 07:29 PM
DC2R96's Avatar
Well it's a motor this is supposed to have less than 40,000 miles on it so I didn't open it up I thought it was going to be alright .. Sucks I just put it in now It's coming back out .. I ordered the Exedy stage 2 clutch kit with Xact prolite flywheel .. I will post on how it looks when I get in the transmisson
fminusmic
14
Feb 1, 2022 05:07 PM
90sedan
Sep 24, 2008 07:57 PM
snzh22
Apr 29, 2008 09:22 AM
Leo C
Jun 17, 2006 06:09 PM
HS2G
Aug 22, 2004 07:34 AM
