Sea foam
Old May 12, 2017 | 10:16 PM
Kennethbtaden's Avatar
Default Sea foam
Is it necessary to change your oil directly if you ran Seafoam thru the brake booster vacuum line.
Old May 13, 2017 | 01:28 AM
holmesnmanny's Avatar
Default Re: Sea foam
Putting seafoam into the brake booster is going to introduce it into the combustion chamber which obviously will not come into contact with oil. If you're talking about seafoaming the oil, which is normally half the use(the other half going into the fuel tank), then yeah you'll want to idle it for a few minutes and then draining it out immediately after.
central_driver
Jul 9, 2006 03:45 PM
amej8
13
Jul 7, 2006 04:24 PM
return_2020
Apr 19, 2005 12:31 PM
sockvtec
Jan 14, 2005 08:03 AM
Del_Slowest
Oct 22, 2003 03:48 AM
