Car wont rev past 5500
Old May 11, 2017 | 11:54 AM
Brandon Hovel's Avatar
Default Car wont rev past 5500
I have a 1998 Honda Civic d16y8 out of a 99. Runs and drives good but when i do pulls it wont go past 5500 rpms. I do throw codes on my ecu because its an auto ecu and wiring harness. I will post codes tomorrow after i get them ran. I am trying to fix this so any suggestions would be helpful and good.
Old May 11, 2017 | 06:38 PM
civic402lx's Avatar
Default Re: Car wont rev past 5500
Get code then report back.
Old May 11, 2017 | 07:27 PM
Rickkyg's Avatar
Got codes yet ?
Old May 12, 2017 | 08:00 AM
mk378's Avatar
Obviously, there will be codes related to the automatic transmission which is not there.
If the CEL is on for any code, the ECU runs in "limp mode" which includes a rev limit. You need a manual EX ECU which also means you need to convert to 2-wire IACV.
Old May 12, 2017 | 10:24 AM
So if i have a 99 obd2b ecu could i buy the jumper for it? How do i wire in vtec to my lx auto harness and the iacv conversion? Im not very smart at wiring at all.
Old May 12, 2017 | 10:31 AM
P0113
P1259
P0700
P1758
P1768
Old May 12, 2017 | 02:38 PM
civic402lx's Avatar
Time to take it to someone who know what they are doing. Preferably before you do more worse then good.
Old May 15, 2017 | 05:41 AM
I am not taking it to anyone. I would rather learn myself. I am getting a manual engine harness with vtec. I have a 99 ecu. I am buying the jumper from obd2a to obd2b so they work together. If that doesnt work then i will reply again
Old May 15, 2017 | 06:38 AM
mk378's Avatar
Again, you will need to put on a manual EX intake manifold and throttle body so you have a 2-wire IACV. It would be simpler to use entirely OBDIIa parts.
Old May 15, 2017 | 06:47 AM
I have the ex manual intake manifold and throttle body
bigmaccrew
Engine Management and Tuning
12
Oct 7, 2018 08:20 PM
CD8coupeSiR
Mar 29, 2007 05:13 PM
93formula
Jan 10, 2007 10:17 PM
blackie
Feb 14, 2006 06:54 PM
swrdply400mrelay
Feb 19, 2003 09:41 PM
