Em1 overheating issue
Old May 11, 2017 | 09:02 AM
JEM1IRL's Avatar
Default Em1 overheating issue
My em1 gets starts overheating and starts leaking coolant from the oil cooler hose up above the oil filter, there seems to be alot of pressure in the cooling system and radiator hoses, the coolant is boiling, I just done the head gasket and water pump. I'm trying to figure out is it boiling and over heating over the leak in the pipe (alot of coolant leaks) or is it leaking because the pressure in the system The pipe on top
Old May 12, 2017 | 08:08 PM
D21X's Avatar
Default Re: Em1 overheating issue
1. Did you bleed the coolant system? If not do a search and you will find out how.
2. What head gasket did you use? Some brands are crap. I always use OEM.
3. Did you install it correctly? I believe there is a top and bottom.
4. How is your thermostat? Did you replace that?
Old May 13, 2017 | 08:23 AM
mk378's Avatar
Engine cold, take radiator cap off start the engine and rev it. If there is a lot of bubbling or stuff blowing out, the head gasket is blown.
If that is OK, attach a pressure tester, pressurize to the normal operating pressure of 15 psi, then find and repair all leaks.
Mhillips
Jul 31, 2013 07:16 PM
Hardedge
Apr 30, 2009 10:55 PM
mortificationrock
24
Aug 11, 2008 11:09 AM
97akwerd
Jul 30, 2005 08:43 AM
sharkcohen
Feb 4, 2004 10:14 PM
