So about 2 years ago i picked up a Bare block from a 01' ITR and well thats when i started my engine build. I decided to make it a all motor setup, high compression semi-stroked everything for the engine has been bought new & machined from decking block to rotating assembly balance & fresh resurface on the head freshly seated valves with new seals.
Almost all the parts are finished being purchased & ill be done with it but im currently not able to decide on what cams to use 😕😕 and was wonder what others can recommend me from experiance & not from a friends cousins friend brother friend type thing.. personal experience. Im stuck between useing skunk2 Tuner 2 cams or skunk2 tuner 3 cams but im open to hearing other options & opinions about what cam i should/could use for best output power along with why i shouldnt use ect. My engine setup is 81x89 12.5:1 compression Cp pistons with Bc LW H beam rods with a OEM thickness headgasket golden eagle Block gaurd and a jdm ITR head stock ITR valves skunk2 alpha dual valve springs & retainers along, header will Mugen 4-1 & 70mm TB with ITR intake
I know you asked for personal experience, but I know several people on here with around your compression have had great results with Skunk2 Pro 2 cams. I don't have experience with those, so I don't know how much the info is worth, but I'm sure a few people with those cams can share their experiences.
Ive been recommend tuner 3 & pro 1's for my setup due to the high compression but im also told the cams will be to big for my small dosplacement & well some even saying tuner 2 is best or just right. I have stock ITR cams but there to small for what i have. Dyno numbers & graph would help with a parts list if your refering a friends setup
Why pro 2 cams, Have you tried that before on all motor? I need reasons as to why you think itll work best dont want to get a cam that wont benifit at all.
his looks like a good build, very simple that port work helped alot too im sure wonder if anyone else has used these for all motor, thanks alot for the input ill look more into them now 🤗
^Pro 3's maybe? What are you getting at 2L with that question just curious?
90% of people on this forum overcam their engines, and I'm sick of people throwing Pro 2s at every thread in the all motor forum like their some magical cam... I've seen them beat out by Buddy Club 3s, so I personally am not as impressed as some of you. I know cams that make more peak power, and cams that will make more midrange, they're really not all that great. Most guys end up with 200-220whp which was being done in 2002 just fine.
Yes they can make power, but I do not think a 1.8 with mid-to-high compression and weak supporting mods is a key candidate for Pro 2s.
