Z0831xiz's 01' ITR High-Compression Longblock Progress Build
#26
re: Z0831xiz's 01' ITR High-Compression Longblock Progress Build
90% of people on this forum overcam their engines, and I'm sick of people throwing Pro 2s at every thread in the all motor forum like their some magical cam... I've seen them beat out by Buddy Club 3s, so I personally am not as impressed as some of you. I know cams that make more peak power, and cams that will make more midrange, they're really not all that great. Most guys end up with 200-220whp which was being done in 2002 just fine.
Yes they can make power, but I do not think a 1.8 with mid-to-high compression and weak supporting mods is a key candidate for Pro 2s.
pro 2 is alot smaller than whats advertised. so unless youve had them degreed, you probably think people are overcamming their engines. maybe this is why people tell you to degree your motors. pro 1 are alot smaller than advertised for example. they are 248/248 at the valve.
#28
I like to party
Intake lift - 12.5
Intake duration - 263
Exhaust lift - 11.6
Exhaust duration - 273
This is not a small cam.
You can backpedal all you want, that doesn't change the fact that you suggest Pro 1s, Pro 2s, and Pro 3s, for every engine in the All Motor forum. Need I quote you?
If anything, the Ultra 1 cam is superior to the Pro 2 in every single way, so I just don't understand why you throw that cam at every motor you see.
#29
@ zero lash, measured @ 0.040 lift. Centerlines are within 1° of the cam card.
Intake
264.5°, +6.5° of advertised
Exhaust
262.5°, +2.5° of advertised
#30
Just degree'd my Pro 1's, duration was longer than advertised, lift was a bit smaller (they are used, might explain why).
Intake
Exhaust
Intake
Exhaust
oh nice man,damn bigger than whats been shown to me(even though says .040). last i seen at my tuner's shop was 248/248. the cam lobes even look small.
#32
was there any sort of port & polishing done to the head? Did you try tuning on 93 pump or e85? Very similar to my setup what stroke crank did you use 87.2mm or 89mm ive always been told tuner 2 or 3 is best never been recommend pro 2's
jaydmcrx
01-17-2005 11:31 AM
Fuzion
13
11-03-2004 05:19 PM
