P.R.E. 82X89 LSV dyno
Old 09-28-2012, 06:21 PM
slowsleeper's Avatar
Default P.R.E. 82X89 LSV dyno
I know some of you guys have already seen this but i figured it may be of use for some members on here. I built this lsvtec on a budget with simple parts and this is on just pump gas because it doesn't have the crazy amount of compression that everyone on here is used to seeing. The car has gone 12.33 at 110+ mph, weighs over 2300 lbs, and is our daily driver.
Still looking to see if more power can be made (if my budget will allow it) with a different header (Jack Myers, SMS, etc E-85, etc so we'll see
Setup is really simple:
82mm RS ITR Pistons
LS crank
stock rods with ARPs
Ported Head
Cams
valvesprings
modded Px (Dynochart of stock Px on page 4)
Toda Copy
-Tou
US ITR Pistons not PR3s, P30s, PCTs haha
Modded Performer X
Last edited by slowsleeper; 11-19-2018 at 12:51 PM. Reason: updated with stock Px dyno on pg 4
Old 09-28-2012, 06:55 PM
DDTECH's Avatar
Default Re: P.R.E. 82X89 LSV dyno
looks great Tou.. you tuned?
Old 09-28-2012, 07:15 PM
Derek, yeah I did the tuning initially as you saw in the video. This was tuned by MA Performance after though because I wanted dynojet numbers.
Old 09-28-2012, 07:39 PM
DA is best's Avatar
We need to race once my h2b is done tou :p
Old 09-28-2012, 08:46 PM
koczeka's Avatar
Beautiful curve, TQ is basically flat from 5k-8.5k, congrats!!!... leave it as it is.
Old 09-28-2012, 09:14 PM
todahead's Avatar
nice numbers congratulations !
compression is ?
Old 09-28-2012, 09:55 PM
Compression came out about 11.53:1 after cc'ing the head, piston to deck, and the rest of the measurements. Like I said before, it's not the usual high compression build that everyone usually prefers to see. Compression is also not the end all be all.
Old 09-28-2012, 10:04 PM
allmotorpackage's Avatar
are those SAE, STD, or Uncorrected numbers? strong setup. any idea how much the head flows?
what was done to the performerX? any ideas on the flow of the plenum? any changes to the runners?
Old 09-29-2012, 03:03 AM
lzylst's Avatar
What injectors are being used?
Old 09-29-2012, 04:39 AM
Andy8's Avatar
What transmission is being used in this setup? Very simple and effective! Great job!
Old 09-29-2012, 04:56 AM
Garrett's Avatar
awesome power with this CR, people overated CR almost all the time without taking time for the detail that really makes power.
the only thing I don't love on your setup is the stock rod @ 9400 rpm
Old 09-29-2012, 07:42 AM
Numbers shown are of STD correction. We didn't flow this head but similar to others we’ve done before which flows around 280 cfm. I had MAP mod the Px by shortening the runners and then blending the transition from the plenum into the runners. Similar to the King one but runner length between mine and theirs may be different.
Injectors were RDX with the tophats all from Xenocron
B16 TRANS
Thanks! Ive seen your Pro1 vs Pro2 graphs too and agree that compression is not everything.
The stock rods with ARP bolts have been going for 3 years strong of daily driving and numerous trips to 10k rpms haha (knocks on wood)
Old 09-29-2012, 07:48 AM
SL0WEGG's Avatar
cool stuff. Heaviest crx of all time
Old 09-29-2012, 08:00 AM
ek4serge's Avatar
Always love your builds ,the numbers are amazing , it just shows you with the right person building a motor you can accomplish great things . I finally got my car running hope to see the dyno soon , going to try to compare a custom header to a off the shelf header and maybe cams etc
Any pics of it on the track
Old 09-29-2012, 08:27 AM
I serve phở for my babies
ohsnapzafingcu's Avatar
solid dyno! lets see some vids
Old 09-29-2012, 08:30 AM
For sure with a B swap, Si, 200 lb driver etc. Need to get into a lighter shell like yours
I got something for ya once it gets going
Old 09-29-2012, 05:02 PM
SR20S13's Avatar
Love this build I need a similar intake manifold and some e85 since I have probably 12.5-1 compression on a 1.8 also just gsr crank and only 81.5mm pistons
Old 09-29-2012, 05:43 PM
ek4serge's Avatar
I'm impatient show me now ,haha
Old 09-29-2012, 07:53 PM
Charlie Moua's Avatar
... i was wondering if you ever going to make a thread on this engine. lol
Old 09-29-2012, 09:15 PM
Hyper16-Johnny's Avatar
Nice numbers, can't believe you're trying to make even more power than that! I can't wait to see the end results.
Old 09-29-2012, 11:05 PM
d112crzy's Avatar
Great build. I have a similar build I'm helping a friend on. I believe I pm'd you a while back about it. Hoping to see at least 210. A custom header should definitely get you some nice power.
Old 09-30-2012, 10:10 AM
blacK_Dc4's Avatar
very impressive! damn near makes more than my 2L. keep up the good work and tell Robert I said Hi
Old 09-30-2012, 05:53 PM
egb18c5's Avatar
nice numbers tou, i keep forgetting to send you an invite on dropbox so you can see my progress on the build similar to yours lol
Old 10-01-2012, 03:09 AM
pithor-c1's Avatar
beautiful job =D!!! how much your pro2+ cams are degraded?
Old 10-01-2012, 08:03 AM
SR20S13's Avatar
I can you tell you on my car which is a 1.8 with ctr and a gsr crank it was +3.5intake +1.5 exhaust or maybe the other way around can't remember haven't looked at them in awhile haha but a good 2* of seperation never got to moving them around because I need to go E85 since all i had was 22* of ignition timing before we started to get pinging,
Quick Reply: P.R.E. 82X89 LSV dyno
