98 R DOWN AND OUT
Old May 8, 2017 | 11:48 AM
98-0145's Avatar
Default 98 R DOWN AND OUT
First and for most I have searched and have came up with nothing. Long story short I picked up a 98 ITR last year that I have rebuilt completely. Picking up the car as a parted shell I threw in a jdm gsr longblock to move it around. After all the repair was done I had absolutely no issues No cels etc Recently I was able to buy back the original motor which is now in the car. I am running the car as stock as possible. Stock airbox, stock exhaust, stock USDM p73 ecu etc. Basically the issue am I am having and can not seem to figure out is code 14, searching for idle. First it was a no brainer, pull the IAC clean reinstall and go.. I Have already cleaned it and no luck, even tried with two other know good working IAC's, with exact same results. After resetting the ecu I can drive the car with no issues at all. Good response, no immediate cels no smoke etc. After driving for roughly 30 minutes or so when coming to an idle is when the car throws the code and idle becomes horrible sounds like its missing really bad, I thought maybe the purge valve solenoid valve could be the issue since I was not running one previously. Any one have any ideas or can steer me in the right dirrection. Thanks
Old May 8, 2017 | 12:59 PM
feck's Avatar
Loved
Community Favorite
Default Re: 98 R DOWN AND OUT
Might be way off here, but I knew a chap with a similar issue with a Civic EK9 R with the similar engine and he went through all the obvious like yourself and it turned out to be the weak point on our engines, the distributer. He swapped that out and the problem went away. Actually I had a kinda similar problem myself. The engine would run fine until it got above a certain temperature and then would run like a three legged horse, cut out, ran rough and then die and again it was the dizzy at fault. Might be worth a look?
Old May 8, 2017 | 01:55 PM
98-0145's Avatar
Appreciate the info I have another I'll try out. Only one way to find out. Thanks
cartune network
Apr 1, 2016 01:02 AM
The Quaff
Aug 16, 2014 04:49 PM
thatwhiteguy
Oct 29, 2006 02:25 PM
Touge Tuning
Sep 22, 2005 11:55 AM
NWPNOMORE
Apr 17, 2002 09:23 AM
