Need Advice on Clutch Prob w/ hatch.....Search did not help 2 much
OK 3000 rpm clutch pedal all the way to the floor you can feel the car trying 2 catch and go slightly.....I have a b18b w/ an ACT 6 puck unsprung.....Is this normal or do i need 2 try an adj the clutch pedal or do something else besides......Need Advice...... Much Thanks Guys.....
Chris>>.......
Chris>>.......
um, i dont think thats normal. your car shouldnt pull when the clutch is pressed. try bleeding the clutch. other than that hopefully someone else knows.
I'd say do a flush and adjust the clutch line. Maybe in the swap it got loose somehow. I recommend readjustment. Make sure that line is good.
*hates clutch problems too* haha
