Building my first ls vtec
Hello, so i just pulled my motor out of 91 hatch. someones been talking **** about my car and hes got a mazda speed 3 that he bought previously built, its a quick little car but i need to prove him wrong. Anyways, I have a b18b1 right now also have a b18b bottom end and block, which would be better for this build? is there even any difference in the block or is it all in the piston and rod length. I am planning on running eagle rods probably weisco pistons arp head studs and rod bolts. I am debating on what head to use, either the b16 or the gsr. I heard the gsr has a slightly tighter tolerance and is less likely to have detonation but it is alot closer to the piston so you gotta watch your tolerance. I have a skunk 2 intake manifold i bought used thinking it would fit on my b18b1 but it did not im going to assume its either a b16 or a gsr manifold. I may just run with whatever fits my manifold. I am going to need to buy new valve seals, bearings, i heard a gsr waterpump is better because it spins slower. probably new valve springs and retainers. golden eagle ls vtec kit with a different head gasket. I am shooting for around 350 hp but i wont complain about more but I do not plan on sleaving my block. I have a ram horn turbo manifold and am planning on buying a t3 t4 to run with it. What compression ratio should I be shooting for? If anyone with a bit more knowledge on hondas can help me piece together the parts I need for this build it would be very much appreciated. Is it even worth it to build a b18 or should I just go with a h22 so I can shoot for higher numbers.
I will obviously need bigger injectors and probably a walaboro fuel pump. chipped ecu too so I can tune it. anybody know of any good tutorials on tuning? i get the concept of it just shooting for the optimum air fuel ratio but theirs alot too it.
your goals can be had on a non VTEC head, why complicate matters with the whole LSVTEC thing? Just build the bottom end, turbo, tune it right and enjoy your 350 or so horses.
SYNSEI
Appearance Build Threads
744
Dec 29, 2013 06:32 PM
The G2 Racer
Dec 3, 2008 05:11 PM
