B-Series Front Torque Mount/Bracket for Hydro
Old May 4, 2017 | 05:52 AM
existanzcivicb20's Avatar
Icon5 B-Series Front Torque Mount/Bracket for Hydro
Does anyone make or has anyone home made a B-Series Front Torque Mount/Bracket for Hydro trans? Reason I am looking for one is because on my trans one of the two bolt holes on the rear trans bracket broke off so not I only have one bolt on the block and another on the bottom hole of the trans. I am trying to give some help to that rear mount basically. Any ideas guys? I added a picture for clarification (not my actual picture).
File Type: pdf
Old May 4, 2017 | 06:11 PM
acmoc's Avatar
Default Re: B-Series Front Torque Mount/Bracket for Hydro
why not fix the rear trans mount. You really need it.
The front mount is really just to qualm vibration.
You're only option is to get a innovative crossmember and front mount.
But it will transfer a lot of vibrations.
Or buy a front mount and have someone weld brackets to your crossmember.
Old May 5, 2017 | 03:07 AM
Cant really fix it a piece broke off the trans case. I think I may have to buy the innovated cross member but the mounts say for cable trans only.
Old May 5, 2017 | 06:46 AM
acmoc's Avatar
hmm, do you mean the bracket that goes on the tranny for the mount that bolts to the sub frame ties to?
Why not weld a stud and put a nut on it
Or just weld the bracket to the tranny
Old May 5, 2017 | 08:38 AM
The problem with that is that the case is aluminum
Old May 9, 2017 | 06:18 AM
bump
mercutio_07
Mar 19, 2008 04:35 PM
PA MATT
Oct 23, 2006 12:51 PM
sackdz
Feb 16, 2005 05:40 PM
Propulsion
Aug 10, 2004 12:05 AM
