Transmission & Drivetrain Gearboxes, Differentials, Clutches
OEM ITR LSD Into YS1 GS-R? Ring Gear Bolt Pattern?
Old May 2, 2017 | 05:35 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default OEM ITR LSD Into YS1 GS-R? Ring Gear Bolt Pattern?
It's been a loooooong time since I've messed with transmissions, and I'm a bit fuzzy on putting an S80 ITR LSD into a cable YS1 GS-R (from 92-93 GS-R with B17A engine).
I know the LSD will fit in the case after grinding the webbing in the diff housing portion of the case, but my real question:
Will the ITR LSD bolt to the ring gear from the YS1 GS-R?
The cable GS-R tranny has the 4.400 FD, so the teeth count is the same. If I recall correctly though, the diff diameter/bolt pattern on the ITR LSD is different from the cable diff/ring gear.
Can anyone confirm this? Must I have a 94-01 Integra GS-R/ITR ring gear to make this work?
Thanks!
Old May 2, 2017 | 08:23 PM
chuck chainz's Avatar
Default Re: OEM ITR LSD Into YS1 GS-R? Ring Gear Bolt Pattern?
It will not bolt onto the cable GSR ring gear, because it's really just a B16 trans which runs a smaller diff/ring gear. It needs to be a 94-01 GSR ring gear.
Old May 8, 2017 | 06:55 PM
Aquafina's Avatar
As said above, you'll need a B16A/LS ring gear (use the matching countershaft unless the ring gear is NIB).
Hope all is well Tom.
muuhda 4 life.
gsrboost737
Sep 3, 2008 06:15 AM
red civic standard
Aug 10, 2008 08:22 AM
fourdoorturbo
Apr 30, 2007 02:16 PM
Blown90hatcH
Oct 19, 2001 08:58 PM
