MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
Old Apr 30, 2017 | 11:42 AM
B_Swapped93's Avatar
Default MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
Came with my k-swap, originally planned to use the k-tuned tucked harness which has labels, ended up sticking with this. I'm lost on which is the TPS or the other the map, I've included pics.
1st pic is a blue plug lower on the harness and just by it's self, I think this is the TPS?
2nd is what I think is the MAP, it has a 2nd plug almost directly attached to it, which isn't used with my ktuned intake manifold/tb.
Old Apr 30, 2017 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
Looks right... the black plug should be the purge solenoid.
Old May 1, 2017 | 03:52 AM
which sits right by the MAP in the stock application, right? I didn't label them, which I should have done or taken pics.
Old May 1, 2017 | 09:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, the MAP sensor and purge solenoid sit next to each other on the top of the stock throttle body.
Old May 2, 2017 | 09:35 AM
Thanks man! appreciate the help.
MMMGIRL
Oct 19, 2014 02:44 PM
10cjennings
Mar 12, 2013 08:01 PM
LS94tegra
Oct 13, 2008 05:17 PM
0ldsk00lef
Aug 22, 2007 08:55 PM
RudeLude95
Apr 14, 2005 11:30 AM
