strut bar installation
Just bought an OEM Si strut bar for my 98 coupe. It looks like I'm gonna have to drill. Anyone know what size bolts/washers I should use?
In fact, if it's the OEM Si bar, it just directly bolts on to the shock tower. Just unbolt the 2 nuts on top of each shock, plop the bat on and rebolt (making sure you don't over or under torque the nuts.
Yes, you will have to drill. I did the same on my car. I will get back to you on the hardware. I think it is M12. I used Honda bolts and nuts. Use as big a washer as you can on the underside. The Si has a reinforcement plate under there.
Sorry again.
My bad guys, I assumed the shock towers of the EM1 Si and the 98 EX Coupe would be the same. I know it is for all EG / EJ1 JDM or USDM.
Sorry again.
Sorry again.
Steve
I don't like those bars cause then I have to drill, which means it is not OEM strength
Steve
NUT, FLANGE (8MM)
