Max compression in turbo/high hp build?
Old Apr 21, 2017 | 02:36 PM
Pumpking.'s Avatar
Default Max compression in turbo/high hp build?
Anyone try 12:1+ in their turbo build?
11:1 right now, and 900+hp. Plugs look good, logs look good, car feels potent...
Doing a back up motor, head, and cam package to swap in once my current motor blows, all with better components... Considering going 12 - 12.5:1 since it seems I still have a decent safety window on my 11:1.
Just curious if anyone has opted to try and go with something out of the normal 9-11:1 range, and if so did you pick up any notable power? Any regrets?
Old Apr 21, 2017 | 08:54 PM
bauergold's Avatar
Default Re: Max compression in turbo/high hp build?
Can you run methanol?
Old Apr 22, 2017 | 10:16 AM
AZ_CIVIC's Avatar
1050whp and 720lbs on 9:1. I have an aluminum rod block I will be doing at 10:1.
Old Apr 22, 2017 | 02:54 PM
dohcsideSi's Avatar
are you running a b or k? If you have the airflow you will make power. I know a lot of the sfwd b series guys are running over 12.5. I've heard 15 in one car but I just can't see that on vp gas. But more compression is the only way to make any more power on the 72mm.
I'd love to run around 12 but it's a street car and q16 isn't cheap.
Old Apr 22, 2017 | 03:00 PM
AZ_CIVIC's Avatar
I would like to know what turbo car over 1000whp is on 15:1 compression?
Old Apr 22, 2017 | 05:43 PM
FastechAccord's Avatar
I am currently running a 10:1 motor, but it seems like I remember Chris Miller running something around 12:1 years ago. Most of those guys don't post here anymore, so it's just speculation anymore.
Old Apr 22, 2017 | 07:20 PM
Pumpking.'s Avatar
I'm in a dodge srt-4, just lounge around on HT more than I do on the srt forums. lol
I was told from a Tx tuner that T1's car was 14:1 at one point, but even if that were true, I'm just a garage built weekend racer, and cant afford to even attempt riding that thin line so closely.
On 11:1, I feel like I have a bit of leeway/window with compression to play with. I assume a bunch of the top sfwd guys are in that 12.x range that you mentioned, so just curious if any with experience had any input.
@bauergold: I'm running sealed ethanol.
Old Apr 25, 2017 | 09:05 AM
dohcsideSi's Avatar
I've heard rumors that Shawn's car is closer to 15:1 i don't see how that is really possible but just what i've heard, he has to be making 1300+
Old Apr 25, 2017 | 09:14 AM
AZ_CIVIC's Avatar
Most people that are super competitive are not willing to really tell you what they have.
Old Apr 26, 2017 | 05:45 AM
dohcsideSi's Avatar
Yeah of course not, I wouldn't even ask.
Thats just what is assumed by other engine builders and tuners with 1100-1200whp cars I talk to.
Old Apr 26, 2017 | 09:10 AM
locash's Avatar
Most of the cars out there at that power level are not 14+:1 compression, that's for damn sure.
The right turbo is a much more important choice than compression. None of my motors are anywhere near 14:1 or even near 13:1 for that matter. You'd be surprised to see how simple they really are.
Old Apr 26, 2017 | 02:24 PM
AZ_CIVIC's Avatar
I will say this, I am pretty close to the 1100whp on a 6870 and am currently at 9:1 on steel rods. My block was done with all off the shelf parts from Real Street Performance. No special piston or coatings, no custom rods, nothing.
Now the next block will be a bit more custom.
Old Apr 27, 2017 | 11:59 AM
JDMarv's Avatar
if you're willing to share, what rods? turbo tuffs?
Old Apr 27, 2017 | 12:28 PM
AZ_CIVIC's Avatar
Yeah, off the shelf Turbo Tuffs.
Old Apr 28, 2017 | 10:25 AM
JDMarv's Avatar
thanks for sharing - keep it up bro!
Old Apr 28, 2017 | 01:42 PM
Pumpking.'s Avatar
Ended up getting a custom set of 12:1s made.
Old Apr 28, 2017 | 06:25 PM
dohcsideSi's Avatar
hey I read in another thread that you used to have the Liberty faceplated gearset. Would you recommend them for a 750whp 2500lb car? Not sure if they are worth it or if I should just save up for a dogbox. It's still something that is driven on the street. Don't really want to turn it into a race only car because of the weight. Just don't feel like dropping a grand and having them blow part too. Any other drivetrain mods you consider must have? And opinion on the trans brace/mid plate?
Old Apr 30, 2017 | 05:40 PM
AZ_CIVIC's Avatar
750 is where I started breaking the liberty gears. For that power if you are looking for reliablility I would save for a dog box.
Old May 1, 2017 | 06:38 PM
bauergold's Avatar
Awesome, your car's going to make great power on ethanol.
90teg
Nov 22, 2017 07:02 PM
acura_b18c1
Sep 4, 2012 03:36 PM
MobRacing2
Feb 24, 2006 06:43 AM
turbo_racer
Aug 21, 2004 12:51 AM
93B17A
Dec 17, 2001 04:34 PM
