Front subframe rust on 2002 Accord
Old Apr 15, 2017 | 06:27 AM
bw77's Avatar
Default Front subframe rust on 2002 Accord
2002 Accord EX 4cyl, 130K miles, upstate NY car.
No problems with the car other than the front subframe rust, pass side only.
Looks like only the rear beam needs to be replaced.
Any tips on replacing the rear beam?
I plan to do it myself with used parts.
Old Apr 15, 2017 | 03:35 PM
jollyhonda's Avatar
Default Re: Front subframe rust on 2002 Accord
I am not super familiar with the 98-02 sub frame...but is that a part that bolts to the body or is it spot welded in?
Old Apr 16, 2017 | 01:12 AM
bw77's Avatar
The subframe bolts to the body.
Old Apr 20, 2017 | 01:16 AM
MAD_MIKE's Avatar
MM Gruppe B
Find a way to re-route the AC drainage line before installing the new unit or it will rust too.
Old Aug 23, 2018 | 02:47 PM
2hisownAccord's Avatar
Did you find a solution to this problem? Many people, including myself have this same issue with the rusted frame on the Honda Accord. Any fix for this?
Is that part pictured replaceable or is it part of the frame?
Last edited by 2hisownAccord; Aug 23, 2018 at 02:48 PM. Reason: needed to add question about frame and part shown in image
Old Aug 23, 2018 | 11:23 PM
bw77's Avatar
I replaced the rear beam of the front subframe.
See my posts #23-24, and others in this thread:
https://www.driveaccord.net/forums/5...gen-psa-2.html
Old Aug 31, 2018 | 04:53 AM
DanInOttawa's Avatar
Just a heads-up to forum members: after a bunch of back and forth with Honda Canada I had the subframe (rear beam) replaced at no cost at a dealer garage on my 2002 SE. The work included all parts and labour except for the alignment, which I had to pay for.
I don't know what the chances are of this being replicated, but in my correspondence and discussions with their reps, I consistently stated that it left an otherwise mint and well maintained vehicle unsafe and usable, that the vehicle was a family car used to transport children, and if the situation wasn't resolved I would file a formal complaint with the Ministry of Transport citing all the threads floating around the internet clearly showing that the condition was the result of poor design and engineering creating an unsafe situation.
I'd found a mint subframe (must have just been replaced before the car was rear ended) at the pick and pull and was arranging a day off to pull it when I finally got the call saying they were going to do it as a one-time goodwill gesture. They mentioned the numerous generations of Accord purchased by my family as a reason for their largess...like I said, your mileage may vary, but at least worth a try.
Old Sep 8, 2018 | 02:45 AM
bw77's Avatar
klowny1969 recently posted an excellent video showing how to do this job.
Old Jan 12, 2019 | 12:57 PM
RoscoeT's Avatar
I'm just buttoning up our 2000 accord after pulling the engine cradle for subframe rust. The new cradle is back in the car and all the PS lines hooked up. I had to replace both lines because galvanic corrosion had just about welded the fittings into the steering rack ... I had to persuade them off with a chisel. That video is helpful, but the part where they popped the lines off of the rack with almost zero effort made me laugh.
I went an alternative route, unhooking the pressure line at the PS pump and the return line where it transitions from a hose to a hard line at the top of the engine cradle. Once the cradle and rack were off the car and out in the open, I was able to get medieval with it.
Here's a pic of the rusty subframe.
Old Jan 14, 2019 | 08:43 AM
jfboy's Avatar
I have had to do this on two seperate 98-02 Accords in Canada. On a rusty car this is a two day job for a lazy backyard mechanic working on jackstands.
Expect to replace the downpipe at the same time (you'll need new bolts and gaskets as both times the downpipe was also ripe from rust. The sway bar end links are also hard to remove without cutting on an old rusty car so I recommend you replace those as well. Easier to cut them off and replace them vs fighting them.
Last but not least, if you can, try to get a rust free subframe/front xmember assembly with a rust-free rack and pinion with lines, radius arms and sway bar. The power steering lines can be a pain when rust is involved so try to get them as well. Easier to buy a loaded Subframe.
Both times I bought subframes from pull a part in Georgia for a very cheap price. Removed it all myself and I took as many bolts as possible. The total cost was less than 100$ from pull a part. In Canada these subframes sell for well above 300$ and they are hard to find.
Now on both cars we just keep the subframe oiled up well in this area so it doesnt happen again. Also in the winter, when I run the front windshield defrost, the AC comes on automaticaly so I turn the AC off so it doesnt drip on the subframe in salty conditions. Salt=bad Salty water=verybad
hanqw1900
Apr 28, 2017 02:27 PM
Sergey.R
Aug 3, 2011 09:51 AM
AccordAve
May 21, 2011 05:51 PM
honda94accord
Nov 20, 2007 09:44 PM
