94 accord ex wont start help
Old Apr 14, 2017 | 05:08 AM
Tom Jara's Avatar
Default 94 accord ex wont start help
I traveled 4 months came back to find my car batery completely dead. Got a new one. Filled the tank up with gas. It was starting good. Now the battery still has juice but it wont start. Is it the starter?
Old Apr 14, 2017 | 07:06 AM
somick's Avatar
Default Re: 94 accord ex wont start help
How long have you had it running?
Give more details of "not starting" What does it do? Does it rotate? Do you hear clicking?
What is the battery voltage reading?
Good luck,
Sam
Old May 17, 2017 | 08:43 PM
Tom Jara's Avatar
Good luck,
Sam
hey. The problem was my battery cables. Now i have another problem. Car starts perfectly. The gears shift smoothly. But the car just accelerates it wont move at all. . I remember this happened a long time ago with another accord i had, it was a fuse. Dont remember which one. Or is it somethi g else. Maybe brakes are locked? Accord 94 ex vtec 2.2
Old May 18, 2017 | 01:12 AM
eksine's Avatar
Accelerates but wont mpve at all? That makes no sense. Anyways yes just get a $10 electric fuel pump motor off ebay and see if it was the fuel pressure, no need to test pressure that way
Old May 18, 2017 | 04:53 AM
Tom Jara's Avatar
When i press the gas pedal. When i want the car to move it doesn't.
Old May 18, 2017 | 03:21 PM
holmesnmanny's Avatar
Whenever you leave for an extended period you always want to disconnect the battery or the battery is going to run down completely and this is when it speeds up its death.
You may just need to replace the cap, rotor, and plugs.
andrew160
Aug 8, 2008 01:18 PM
killersoundz
Dec 14, 2007 01:54 PM
wubbena
Aug 12, 2007 05:42 PM
djryan
Jul 13, 2007 03:37 AM
imports
Aug 18, 2006 04:37 PM
