2000 civic won't start cold
Old Apr 12, 2017 | 09:44 PM
Hondarambe's Avatar
Default 2000 civic won't start cold
Hello. I just picked this car up. It's got the d16y7 and 5 speed. When the temperature hovers around 0 degrees Celsius or below the car won't start. It will crank and sometimes sputter on the 1st try then just continue cranking. Plugs, wires, cap and rotor, air filter and coolant temp sensor have all been replaced so far. I can smell fuel once its been cranking for a while. Car starts fine when it's warmer outside, but idles rough. You can push start it though when cold. Smooths out once you accelerate. There are cel codes for evap emission control system leak fuel tank system (p1456) random multiple misfire (p1399) and codes for both o2 sensors. (P0135 and p0141) I believe there is fuel getting into the oil but it might just be from all the excess cranking. I'm thinking fuel filter or fuel pressure regulator next but really not sure. Any help will be greatly appreciated!
Old Apr 13, 2017 | 05:26 AM
joey1320's Avatar
Default Re: 2000 civic won't start cold
Why not fix the issues the CEL is on for? Then see what happens.
Old Apr 13, 2017 | 05:42 AM
mk378's Avatar
+1. Don't expect any car to work properly with codes set. Getting both O2 sensor heater codes sounds like a fuse 15 situation.
Old Apr 13, 2017 | 08:59 AM
DanielP's Avatar
Ya, fix the issues the codes are throwing first, usually it tells you those for a reason, then go from there if the problem persists.
Old Apr 13, 2017 | 10:28 AM
Hondarambe's Avatar
I'll check into fuse 15. What is the common issue just a blown fuse causes codes for both sensors? The car has a header and full aftermarket exhaust so im thinking that's what the code might be because of. As for the evap fuel system code I don't even know where to start lol
Old Apr 14, 2017 | 03:08 AM
mk378's Avatar
On 1996 to 2000 models there is a place on the back of the engine where the wires rub on metal and short out. Search for Civic fuse 15 it is a very well known problem.
Old Apr 14, 2017 | 02:08 PM
Hondarambe's Avatar
Thanks. So fuse 15 is good. Also I've never had a problem with my speedometer so guessing that's not the issue. Tested for spark and wasn't getting any on cylinder 1. Tried a different wire and boom there's spark. Going to go get a replacement wire and hopefully she fires up. Fingers crossed!
Old Apr 14, 2017 | 04:05 PM
Hondarambe's Avatar
So looks like that wasn't the problem after all. I've tried 3 different sets of wires and 2 sets of spark plugs. Ive confirmed spark on all 4 cylinders. What's next?
InTheZoneAC
May 9, 2012 05:12 PM
tpot90
Oct 17, 2008 02:17 PM
Maireeka
16
Aug 9, 2007 06:46 PM
ea_hatch
Aug 30, 2005 10:04 PM
chuck23957
Dec 3, 2004 11:26 AM
