EG6 exhaust
EG6 exhaust
Just wondering if this magnaflow high flow cat will bolt up to my eg6, I have a stock manifold and bought a yonaka cat back, wanted something better but I didn't have the money at the time. The exhaust matches up with the stock cat but I just wanna be sure before I spend money on the magnaflow. Thanks guys
Exhaust http://www.garage16.ca/yonaka/yonaka-catbacks-stainless/ymcb004/i-2196569.aspx
cat http://www.garage16.ca/magnaflow/magnaflow-catalytic-converter-directfit/22635/i-156912.aspx
Re: EG6 exhaust
Should be fine.
I have the yonaka cat back bolted up to my after market high flow cat.
The 3 bolt flange outside dimensions appear to be standard. Where it changes is the bore diameter depending on the size/type of catalytic converter. Stock uses a smaller pipe than the high flow variants.
Re: EG6 exhaust
Right on man thanks a lot. Do you know if I can just go to my local parts store and pick up a spring bolts kit for any 92-95 civic to mount it?
Re: EG6 exhaust
I've collected a few from the junk yards when they cut the cat out leaving the bolts and flanges in place.
