Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch pedal/bleeding woes
Old Apr 10, 2017 | 02:54 PM
Zachary Bergman's Avatar
Default clutch pedal/bleeding woes
Zachary Bergman , 04-10-2017 10:51 PM
so, I'll start off by saying I'm fairly new to the honda scene, furthermore this is the first manual car I've driven.
so I've replaced both master and slave cylinders for the hydraulic clutch line and have bled the system multiple times, based off multiple posts here. I've done it by myself and with a friend, not sure if to the tee or not, but I've gotten good pressure built up and gravity bled prior to manually bleeding it(redundancy is always a sure fire way to make sure it's done right, right?), but I keep noticing a really odd trend. After I get really good pressure built up, if I were to put my hand on it slowly, as you would if you were driving, the pressure I had built up is totally lost and depresses to the floor. What gets even more odd is when I slam my hand down on the clutch pedal again, the clutch slave moves and the mechanical arm sticking outside the transmission will move and I can put it in gear. So it's like there's only pressure built up at the time I exert a good amount of force on the pedal and that's maybe with a 60 percent success rate. Does anyone have any ideas on what that might be?
Zachary Bergman
Apr 16, 2017 12:06 AM
Zachary Bergman
Apr 11, 2017 01:32 PM
EddieLe76
Jan 14, 2010 01:50 PM
herde1724
May 22, 2004 04:22 AM
2k1_ITR_0736
Jun 2, 2003 05:12 PM
