Clutch pedal woes
so, I'll start off by saying I'm fairly new to the honda scene, furthermore this is the first manual car I've driven.
so I've replaced both master and slave cylinders for the hydraulic clutch line and have bled the system multiple times, based off multiple posts here. I've done it by myself and with a friend, not sure if to the tee or not, but I've gotten good pressure built up and gravity bled prior to manually bleeding it(redundancy is always a sure fire way to make sure it's done right, right?), but I keep noticing a really odd trend. After I get really good pressure built up, if I were to put my hand on it slowly, as you would if you were driving, the pressure I had built up is totally lost and depresses to the floor. What gets even more odd is when I slam my hand down on the clutch pedal again, the clutch slave moves and the mechanical arm sticking outside the transmission will move and I can put it in gear. So it's like there's only pressure built up at the time I exert a good amount of force on the pedal and that's maybe with a 60 percent success rate. Does anyone have any ideas on what that might be?
Return both parts you bought.
then buy these:
http://shop.exedyusa.com/exedy-oem/exedy-oem-clutch-master-cylinder/mc238/i-128285.aspx
http://shop.exedyusa.com/exedy-oem/exedy-oem-clutch-slave-cylinder/sc646/i-130118.aspx
Oem brand. I use exedy on my civic and integra.
then buy these:
then buy these:
MC238 - EXEDY OEM Clutch Master Cylinder - EXEDY Globalparts - Performance and OEM Clutches and Flywheels
SC646 - EXEDY OEM Clutch Slave Cylinder - EXEDY Globalparts - Performance and OEM Clutches and Flywheels
then buy these:
redline7
Feb 23, 2008 08:53 PM
RTW DC2R
Jun 23, 2006 07:42 AM
