civic ex high beams ground, low beam no ground
I have a 2002 Civic EX. A week ago, when i got my emissions done, the inspector slammed my hood. Until last night, I didn't need my headlights. The will not turn on at all. Not sure if its related.
Running lights work and high beams work. The bulbs looked borderline so I replaced. The fuses are good and relay is good. Im getting power at the connector, and when the high beams are active, the connector is grounded with two hots. But when the lows are active, there is no ground and three hots. If I shoot ground to the pin while lows are active, they work. Switch or bad ground maybe? If ground, then what is the location?
HELP PLEASE!!!
HELP PLEASE!!!
Hello,
Does this happen to both low beams on the right and on the left ? .... Check the socket for oxidation that makes bad connection between the ground and the bulb. Could be the ground wire to the low beam. Check the wiring to the lights for anomalies or cuts. As a temporary solution ... you may connect a ground wire to the low beam.
Good luck
amc
Good luck
amc
The person I bought the car from installed some things that required wiring. When I removed the cover under the steering wheel - omg. It is a cluster of wires and it looks very ominous. If I have to trace the wiring, I'm a little scared.
Thanks in advance for any help!
Kirk Hoey
Honda Civic (2001 - 2005)
Sep 28, 2019 11:25 AM
standerby
Oct 29, 2016 03:31 AM
g4hatchie
Nov 13, 2004 10:16 AM
