2000 honda civic D16Y7 over heating
Old Apr 7, 2017 | 06:49 AM
daleamell7500's Avatar
Default 2000 honda civic D16Y7 over heating
What might be the cause of the engine overheating,
so far I have changed the water pump radiator cap cooling fan temperature sensor and relay, replaced the head and head gasket , correctly time the engine replaced the engine thermostat, cleaned and flushed the radiator.
Old Apr 7, 2017 | 08:22 AM
Txdragon's Avatar
Default Re: 2000 honda civic D16Y7 over heating
Making sure all the air is out of your cooling system at this point should be top priority. Everything you have done is essentially everything you can do. If "burping" your system doesn't solve it, gas and a match will be your only solution
Old Apr 8, 2017 | 01:20 PM
autocraig's Avatar
Have you also checked if your oil level is low?
erndog
Honda Civic (2006 - 2015)
16
Aug 31, 2019 08:24 AM
Donmiller50
Honda CR-V & Element
Feb 25, 2018 09:28 AM
jasb750
24
Oct 28, 2013 11:40 AM
m3touk_85
13
Dec 14, 2011 06:57 AM
windg@t
Aug 4, 2003 08:48 AM
