Honda Crv whining noise under hard acceleration
My 2006 Honda CRV has a whining noise from the rear when accelerating hard. I thought it could be the rear diff but I had the oil replaced and it is fine. The car has done 250 000km. Could it be the wheel bearings or the rear drive shaft/prop shaft
Has anyone experienced the same issue?
Is your 2006 CRV an Integra?
Acura stopped building the Integra after 2001, where were you able to find a 2006 Integra?
the DC5 is technically an Integra. Plus, everyone knows this is the best forum for tech!OP, you're in the wrong forum. Post your query here:
https://honda-tech.com/forums/honda-element-cr-v-156/
I know this is an old thread, but check your upper transmission mount. these are known to go bad, and when they do go bad they cause whining under hard acceleration.
bruce_s2k
Honda S2000
Oct 11, 2006 03:44 PM
