Vtech oil pressure switch bypass
Old Apr 3, 2017 | 05:53 PM
Shon Soto's Avatar
Default Vtech oil pressure switch bypass
I have a 95 eg coupe..has a jdm b16a swap with virgin p30 ecu..i pulled the whole swap out from a 93 eg coupe..when in the 93 everything work fined..vtech cracked no checks..when i put it in my 95 coupe..vtech doesn't work..iv tried hooking it up the right way threw shock tower harness into ecu..doesnt work..iv tried re-grounding the solenoid
.doesn't work..and also tried jumping the two like many has said to do..doesnt work..all ways iv done it..it doesnt throw any codes while cruzzing..but once you mash it thru 5800 rpms..check pops on no vtech..i need some help..im stummped..i dont know why it worked in one but not the other
streetracerof06
May 10, 2006 07:46 PM
92hybridAccord
May 10, 2004 07:12 AM
triplede
Jan 13, 2004 10:55 PM
eg6ajk
Mar 30, 2002 02:42 AM
