1995 Civic VX with p32 manifold-EGR question
Old Apr 3, 2017 | 12:15 PM
middletons's Avatar
Default 1995 Civic VX with p32 manifold-EGR question
I have a '95 VX (D15Z1) and the PO has installed a p32 intake manifold. As there is no EGR setup on p32 manifolds, the harness connector for the EGR is not connected to anything. It seems to run ok (aside from stuttering idle after deceleration when warm) with no CELs. Is this ok to run like this until I can find am actual VX manifold? I do have the proper p07 ECU installed.
Old Apr 5, 2017 | 06:43 AM
middletons's Avatar
Default Re: 1995 Civic VX with p32 manifold-EGR question
Any thoughts? Could the unconnected sensor connector be causing bad performance?
Old Apr 6, 2017 | 05:16 AM
94eg!'s Avatar
#1 Super Guy
Loved
An intake manifold upgrade requires a different engine tune. Personally I would try to find a VX manifold if I wanted to run the stock ECU.
I'm surprised the stock ECU isn't throwing a CEL for no EGR. Are you sure the check engine light works?
Old Apr 6, 2017 | 11:03 AM
middletons's Avatar
it does. I had to troubleshoot a few codes when I got the car. In addition, I can pull the IACV connector and it'll throw the appropriate code. I've been on the lookout for a stock VX manifold, but no luck.
92ehatch
Jul 24, 2007 04:57 AM
slcivic
Jun 26, 2006 08:27 AM
neutron91
14
Dec 21, 2004 07:41 AM
RyanR
Feb 2, 2004 12:33 PM
