Suggestions on EMS Options for an E85 All Motor Project
Old Mar 20, 2017 | 09:06 PM
AdrianArteaga98's Avatar
Default Suggestions on EMS Options for an E85 All Motor Project
Hey guys, so im really confused on what ecu to have for mu all motor e85 setup. Right now i have a gsr block with stock rods and ctr cone pistons with a b16 head with skunk2 dual valve springs and titanium retainers, i have blox type b cams and skunk2 ultra street intake manifold along with a 70mm throttle body. I wanted to go e85 so i bougnt 750cc rc injectors with aem fuel rail and pressure regulator. I also have a 255 fuel pump but i got a blox 300 e85 fuel pump but i was wondering if i can still use my chipped p28 with this setup without having problems on the dyno. Any advice to make this setup more safe??
Old Mar 21, 2017 | 10:26 AM
Lau Cac Bo's Avatar
Default re: Suggestions on EMS Options for an E85 All Motor Project
E85 will eat stock fuel lines. Replace them all. From pump to rail.
Old Mar 21, 2017 | 10:30 AM
hey i have new fuel rail, injectors, and fuel pump. I was just wondering if i can use my chipped p28 with hondata for e85?
Old Mar 21, 2017 | 10:32 AM
[QUOTE=Lau Cac Bo;51234992]E85 will eat stock fuel lines. Replace them all. From pump to rail.[/​​​​​​
my bad i meant without hondata
Old Mar 21, 2017 | 10:35 AM
Lau Cac Bo's Avatar
Yea but what lines though.. old deteriorating oem fuel lines are weak. E85 will easily eat through. Fuel leak, Spark, Fire, Death!
Old Mar 21, 2017 | 10:37 AM
Lau Cac Bo's Avatar
Hey guys, so im really confused. Any advice to make this setup more safe??
Old Mar 21, 2017 | 10:40 AM
Lau Cac Bo's Avatar
you can still utilize the chipped p28. I'd return the 750 injectors and get 1000+ ID injectors.
never thougbt of fuel lines, which ones would you recommend?
Old Mar 21, 2017 | 11:01 AM
Lau Cac Bo's Avatar
You can use any e85 compatible aftermarket fuel lines. better safe then sorry. car fires are no joke!
Old Mar 21, 2017 | 11:08 AM
yeah man thanks a lot. And you said i can use my chipped p28 without hondata with this setup right?
Old Mar 21, 2017 | 12:48 PM
TheShodan's Avatar
Moderator
Only if you have the hardware to change the tune of the chip that is already burned into it. Otherwise, you must retune in some way or form completely. Which means hondata. E85 doesn't have the same BTUs as race fuel and won't account for your larger injectors. therefore you must retune completely.
750cc for NA is plenty. No need for 1000cc on an NA Car for that power level
Old Mar 21, 2017 | 02:30 PM
my boy has a hondata V1, is that good enough or do i need V2 or V3??
Old Mar 21, 2017 | 07:24 PM
TheShodan's Avatar
Moderator
If you need Hondata, just get the latest version of S300 V3, and be done with it.
Old Mar 21, 2017 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Engine management is the MOST IMPORTANT part of a custom build... it exists to synergize all components that you have brought together. You likely have made a substantial investment in the parts inside your engine... why place these parts at risk by using an online freeware program to "chip" your existing ECU ??? Hondata s300v3 is affordable... get one and do it right. As for the s300v1... ALL of those should be upgraded to a v3 before the internal battery fails and the system is rendered useless... so unless you get it from your friend for FREE, don't bother.
Old Mar 23, 2017 | 07:00 PM
Right on guys, ill go with the v3
Old Mar 23, 2017 | 07:24 PM
Oh and i can use my stock fuel filter right?
Old Mar 24, 2017 | 05:45 PM
TheShodan's Avatar
Moderator
Nope.You'll degrade it. Nothing "stock" on the fuel system will help you on E85
Old Mar 24, 2017 | 06:00 PM
Which one would you recommend? I can't seem to find one for e85
Old Mar 24, 2017 | 06:35 PM
TheShodan's Avatar
Moderator
Plenty of choices. You just have to go as an inline filter, possibly.
Look to AEM, Fuel Lab, and Aeromotive..
I hate E85, but I've dealt with that fuel in other projects that are not my own
Old Mar 26, 2017 | 08:02 PM
jdblock's Avatar
Run a fuel system that is alcohol compatible. Ethanol is alcohol.
Old Apr 17, 2017 | 06:54 PM
wunfstgsr's Avatar
Loved
Community Favorite
Have to use S300 V3 with GM flex fuel sensor as well as mentioned fuel lines. Im looking into using AEM infinity EMS instead of S300 V3
Beau Gotti
Oct 11, 2006 03:41 AM
integraracer94
Jan 27, 2004 05:36 PM
Malice
Mar 10, 2003 07:18 PM
pushr0djunk
Feb 17, 2003 12:49 AM
Brian_92GSR
Oct 25, 2001 11:27 AM
