need opinions on oil drain route
Old Mar 20, 2017 | 05:10 PM
cityofcaterpillars's Avatar
Default need opinions on oil drain route
So I'm mocking up my turbo and ran into a small problem. I got a drain kit from fast turbo and I don't know if it's going to work. It's super short. I have the original fitting for the turbo and rubber hose I was going to use before I ordered the fast turbo kit. I could really use some advice on which route to go.
Fast turbo fitting
original fitting
option 2 with rubber hose
option 3 using AN fitting on oil pan
Old Mar 20, 2017 | 06:32 PM
93h2beg's Avatar
Default Re: need opinions on oil drain route
what size hose?
Old Mar 20, 2017 | 06:42 PM
the braided? I have no idea. It goes on a -10 AN fitting if that helps
Old Mar 21, 2017 | 05:51 AM
LightningTeg's Avatar
Community Builder
#3. KISS
Old Mar 21, 2017 | 08:14 AM
TheShodan's Avatar
Moderator
Use the rubber hose using a steel barbed fitting that can be welded to the pan. I use those on low-sitting "Mini-ram" manifolds using GT series all the time.
Old Mar 21, 2017 | 01:14 PM
Rubber hose it is then. I never expected the fittings to be that close together. thank god for mock ups
Old Apr 5, 2017 | 12:33 AM
CivicxTree754's Avatar
Photogenic
Loved
That first braided line is proabably a feed line, you should use it. Also check to make sure its not restricted. Mines was, drilled out the hole...problem solved.
Old Apr 5, 2017 | 07:28 PM
TheShodan's Avatar
Moderator
Umm.. That is a nylon hose line for return. But good suggestion on drilling out the exit hole.
Old Apr 6, 2017 | 03:02 AM
I will definitely check out the feed line for restriction. Its a lot smaller in diameter than the original greedy one which I'm kind of iffy about
sheepey
Apr 22, 2010 09:33 AM
rubyred
Jan 6, 2006 08:56 PM
TheYellowDart
Mar 7, 2005 09:09 PM
VacantBanana
Apr 15, 2004 04:33 PM
ZCHF
Mar 14, 2003 12:38 PM
