trans main shaft bearing
Hi everyone,
i have a quick question about my 99 accord 2.3L 5spd manual
The trans has started to rattle. Im pretty sure that it is the main shaft input bearing.
It rattles with the clutch released, in neutral or driving, slight pressure on the pedal does not change the rattle at all. The rattle only stops when the clutch is fully pressed.
I have been looking on line for a replacement bearing and seal, but im only able to find
bearings for 95 - 05 civics. Does any one know if this is the same bearing for my accord?
if not does anyone know where i can buy the bearing or a part number.
I have called the dealer they want $100 for just the bearing then another $25 for the seal.
That just seems a bit steep for a bearing and seal, that is why i started looking on line for the bearing.
any input or info would be appreciated,
thanks
thanks
http://www.hondapartscheap.com/auto-parts/1999/honda/accord-sedan/ex-trim/5-speed-manual-engine/transmission-manual-cat/mt-clutch-housing-scat
You'll need the seal too so parts 8 and 11
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
Pbanto
Apr 8, 2009 05:07 AM
Wes V
22
Oct 25, 2003 12:51 PM
