D17a2 Injectors 550cc or higher
Good day everyone! I've been looking through the posts but can't find exactly what I need. I'm building up my d17a2 and need bigger injectors I've heard that I can order whatever CC I need but to order it for the Acura rsx and that will fit. But what rsx?? What year and do I get them for the base model or typ-S or what? And these will fit on stock d17a2 fuel rail? I've heard I need longer studs but I can work that out. Now I've fitted a modded y8 intake manifold onto my build and with a homemade bracket and O rings, I have it sealed perfectly. I'm running this build with a KPro and crowed stage 2 cam and spring set. So if anyone could provide me with this information, I'd be extremely grateful. Also, if someone could tell me of a specific set of injectors, that would be perfect. I'm looking for 550cc or 750cc. Thank you guys!
sorry for the late reply, I expected a notification if anyone replied. ^^ but yes! I plan on running a turbo in the near future. I'll be running crower stage 2 or 3 cam(already have stage 2 but I'm thinking of upgrading.) ARP head studs and bolts and rod bolts with a cometic head gasket. I'm hoping to run up to 15lbs of boost. Do you know of the proper(or workable) injectors to run?
15lbs of boost, you'd probably be fine with 550cc injectors on a more streetable tune. 750cc would be if you want to push the engine to its maximum potential, but I'd recommend doing some work to the head to match that (valves, etc...).
alright, but I still need to know what injectors to get. Lol
Most aftermarket injectors will require you to wire them in, so I don't know what you're looking for. Are you asking what engine you should be buying for?
yes, people talk about RC 550s or rsx injectors, but I need more specifics. What year or engine rsx, or what motor to buy for from RC.
The intake manifold will dictate what RC injectors you buy. RSX injectors don't change, as far as the cup specifications are concerned, so whatever RSX injectors you choose will fit the same.
