Transmission & Drivetrain Gearboxes, Differentials, Clutches
Clutch problems, please help!
Old Mar 8, 2017 | 04:33 PM
Ashwell33's Avatar
Default Clutch problems, please help!
Ok so the car i am working on is a 1996 accord. Before I bought it the previous owner had replaced master cylinder for the clutch. It never had good feel, but I was driving down the road and I could just barely get it in gear. Just enough to get home. There was no fluid in the resivior and I noticed it had a slow leak before this happened. So i replaced the slave cylinder and have tried bleeding at the master cylinder and by the slave cylinder but it will only push out a few bubbles and a little fluid then nothing. The method of bleeding I used is cracking the bleeder pushing pedal to floor. Close the bleeder and bring pedal to the top and repeat. I am stumped and don't know how to fix it. So i figured i'd come here to ask you guys. Any help will be greatly appreciated!
Thanks, Ash
Old Mar 9, 2017 | 09:25 AM
Aquafina's Avatar
Default Re: Clutch problems, please help!
You need to pump the pedal before opening the bleeder. It requires two people and can take a long time if there is air in the system.
Old Mar 9, 2017 | 09:41 AM
Ashwell33's Avatar
I have done that aswell, seems like i cant get anything to work.
Old Mar 9, 2017 | 03:28 PM
Aquafina's Avatar
If the cylinders are good, the system is sealed and all air has been evacuated it will work properly.
Old Aug 25, 2017 | 04:47 AM
Karen Staggs's Avatar
Thanks, Ash
I had the same problem after installing master and slave in 02 Civic. Worked for hours until I bought a bleeding pump. Turned out the new slave cylinder had a faulty bleed screw with burrs on the threads. Put some Teflon tape on bleeder screw and worked like a charm.
Old Feb 15, 2019 | 11:54 AM
Ledhole67's Avatar
Thanks a lot! Your post saved me a lot of work!
JDMswagSerf
Dec 10, 2013 09:47 PM
Steviebix33
Aug 14, 2011 07:43 PM
ex_ricer
May 26, 2007 11:01 PM
3rdGteg
Nov 5, 2002 01:21 PM
Accord15
Nov 1, 2002 08:11 PM
