I need help!!!
Old May 26, 2007 | 12:29 PM
ex_ricer's Avatar
Default I need help!!!
My master cylinder just blew, and i replaced it. I properly installed it and rebleed the system. Then recently my clutch pedal has no pressure again. I checked the master cylinder, and its not that. wat else could it be? I checked the reservoir and it was empty, so I put in more fluid, pumped my clutch pedal, and after 5 minutes of pumping my reservoir was empty once more. I refilled it AGAIN, and just left my car overnight due to frustration, next morning the reservoir was empty and i didnt even pump the pedal. any help on what could be the problem now?
my car is 1994 acura integra.
Old May 26, 2007 | 04:16 PM
Sam92Teg's Avatar
Default Re: I need help!!! (ex_ricer)
slave cylinder
Old May 26, 2007 | 10:37 PM
ex_ricer's Avatar
Default Re: I need help!!! (Sam92Teg)
that wat i was thinking.
any other suggestion/inputs?
anyone kno where the slave cylinder is located?
Old May 26, 2007 | 11:01 PM
numbnuts22715's Avatar
look down at the front of the transmisison. Its between the tranny and the radiator.
Youll see a little nipple looking thing pointing out diagonally to the left and front of the car.
Also, you should see clutch fluid leaking on the splash shield and whatnot if that is the culprit.
Hope I helped.
Ashwell33
Transmission & Drivetrain
Feb 15, 2019 11:54 AM
JDMswagSerf
Dec 10, 2013 09:47 PM
Born2Build
May 22, 2011 06:02 PM
ricerEJ8
Feb 23, 2008 04:04 PM
ebp 99 si
Apr 2, 2004 08:10 AM
