95 accord stripped timing belt tensioner bolt hole
Old Mar 2, 2017 | 11:00 AM
Anthony Edwards's Avatar
Default 95 accord stripped timing belt tensioner bolt hole
I've seen a lot of posts about this but most of them seem to be kinda old. I'm wondering what's the best way to make sure my timing belt tensioner bolt will stay in the stupid hole. I've tried jb weld twice and the bolt came loose both times due to expansion inside the block. I've read about helicoils and taps and what not and I'm wondering if there's an epoxy specifically for this problem. Any advice would be great!
Old Mar 3, 2017 | 05:40 AM
smithers646's Avatar
Default Re: 95 accord stripped timing belt tensioner bolt hole
Helicoil
Old Mar 6, 2017 | 08:16 AM
I realize this is an old thread but I would like to add that you can feed nylon rope into the first cylinder and the crank won't turn. Then you just smack your ratchet with a hammer and the crank bolt will come loose.
WaryDriver
27
Oct 7, 2015 08:42 PM
mem94043
Feb 19, 2012 01:38 PM
SPL KID
Apr 17, 2004 01:14 PM
JLange
Sep 25, 2003 07:53 PM
3rdGteg
Apr 23, 2002 02:48 PM
