Quick question *motor compatibility
Old Mar 2, 2017 | 02:21 AM
89ED's Avatar
Default Quick question *motor compatibility
I need another motor for my cb7. I have to replace the block on my stock f22a4. I'm going to be pulling my replacement from the junkyard. my question is what is the newest year car I can pull from. year of the car doesn't mean the engine will be any good. I got that.
Old Mar 2, 2017 | 04:39 PM
HondaTechMan121's Avatar
Default Re: Quick question *motor compatibility
u have a lot more to worry about since u live in CA u got Smog and laws u have to follow with engine swaps any H or F engine will bolt up but sense u have to use a engine from a new year then yours try for the f22b1 from USDM 1994-1997 Honda Accord EX its a vtec engine so take the ecu when u take the engine that's ofc if u don't have a tune able ECU hope u fine the right engine for your car
Old Mar 3, 2017 | 10:27 PM
MAD_MIKE's Avatar
MM Gruppe B
If you only need the short block(no head) then 90-97 Accord F22 engines will work. Only difference IIRC is that the B1(VTEC) block will need the VTEC oil feed gallery to be plugged for the non-VTEC head.
Old Mar 4, 2017 | 08:58 PM
89ED's Avatar
Nice thanks. I have an a4 with a spun bearing. I think my plan is to build a motor. f22a or f22b block with f22a6 head+ecu and h22 intake and exhaust. with a setup like that what ecu options do I have? I don't think I have many. the original pt6 p28 or teg LS pr74 or 75.
Old Mar 5, 2017 | 07:22 AM
89ED's Avatar
Also like I said I spun a bearing. I'm almost certain. I didn't throw any rods. do y'all think it's would be OK to rebuild the original block?
Old Mar 5, 2017 | 08:06 AM
GhostAccord's Avatar
It's hard to say if it would be worth rebuilding without knowing the extent of the damage that caused the bearing to slip.
Old Mar 5, 2017 | 11:32 AM
89ED's Avatar
Yes I'll have to take it out and let the machine shop decide.
dzvero
Honda Civic (2006 - 2015)
Apr 1, 2018 10:26 AM
Topher75
Honda Civic (2001 - 2005)
May 28, 2013 05:09 AM
cryingsuns
Southern California
Mar 18, 2011 07:29 AM
TAmos827
Dec 3, 2008 10:46 AM
