Bone stock 99 civic ex steering creaking
Old Feb 27, 2017 | 04:31 AM
Marvin1985's Avatar
Default Bone stock 99 civic ex steering creaking
Trying to narrow down a creaking sound that happens ONLY when it's cold outside and coming from driver side front corner. Car was up in the air and all ball joints are solid with no play. Sway bar links look to be possibility. Anyone have experience with this issue? Just looking for some insight on the problem. I don't wanna just throw parts at it.
Old Mar 6, 2017 | 09:27 PM
Marvin1985's Avatar
Default Re: Bone stock 99 civic ex steering creaking
Old Mar 6, 2017 | 10:37 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Are you sure it's on the outside of the car and not inside on the steering column when turning the wheel?
The column would be on the drivers side of the car at least. I know my 95 column squeaks sometimes when I turn the wheel. I haven't looked up the lube points or the type of lube Honda recommends.
Not sure if this applies to you but thought I'd throw it out there.
Old Mar 7, 2017 | 04:35 AM
dsol's Avatar
I am having this same problem with my 2002 Acura CL. again only when its cold and on the drivers side. ball joint and wheel bearings seem solid.
Old Mar 7, 2017 | 05:05 AM
mk378's Avatar
If you can get it to make the noise with the car sitting still, have someone else turn the wheel while you walk around and listen for exactly where it is coming from.
Old Mar 13, 2017 | 12:04 AM
Marvin1985's Avatar
changed the sway bar endlinks since they needed done anyway. Still same issue. Also when car is up in air, it won't make the noise. Makes me believe it's the shock top hat rubber insulator or just the shock in general. Car requires some weight on it to make the noise. High miles (185k). Bought it recently like this. I'll keep posted later when I do find issue.
Big1000
10
Dec 5, 2018 02:10 PM
00siandrew
Honda CR-V & Element
Jan 5, 2015 12:42 PM
zipthehuh
Oct 1, 2013 11:32 AM
aberle99
13
Jan 30, 2008 12:37 PM
JoshRambo
Nov 1, 2002 01:30 PM
