Weird Idle sound
92 honda civic hatchback
d15b,
p28 ecu
automatic
every time i start my car up, it does this. i've already took off the IACV and cleaned it. What else could it be?
click the link below for the video.
https://*******/WYi9
d15b,
p28 ecu
automatic
I posted a thread on here a while back, and i uploaded a video of me checking the codes, and the codes i got 1, 10, and 14
This is when i had a stock P07 ecu
I now have a p28 ecu
code 1- Heated oxygen sensor A
code 10 - Intake air temperature sensor
code 14 - Idle air control valve or bad ECM
I was thinking since i've changed the ecu, the codes would be the same.
Check the codes again. You may have the IAT plug swapped with the IACV. The two wire plugs are all the same. You need to check the wire colors to be sure they are plugged in the right place. (Do NOT just try swapping them, that can cause damage).
I'll take pictures when I get back to my car at 3:30PM EST and I'll post them to make sure I got them connected right.
But if i need the intake air sensor, this is what i'll need right?
The IAT is shown in the pictures???
the IAT is the one on the far right of the intake manifold right? shown in picture #3?
in picture #1 & #2 what sensor is that to the left of the IACV?
The black thing with vacuum hoses on it is the purge solenoid-- and it's not plugged in.
I think the IAT is directly underneath it, and it is white.
You have at least 4 two wire plugs back there to consider:
IAT -- Green+white & red+yellow
IACV -- blue+yellow & yellow+black
Purge -- yellow+black & red
Power steering pressure (if equipped) -- brown+red & black
I posted them hoping someone show a helping hand and point me in the right direction . my bad if i posted the wrong pictures.
Which connector is the IAT
Thanks
Colors of all the wires are in this sticky
https://honda-tech.com/forums/honda-...guide-3146770/
Okay the IACV, the wire going in to the connector was solid red wire with yellow wire/black stripe
IAT colors were red wire with yellow stripe & green wire with white stripe
MWLW20
41
Aug 28, 2009 04:45 PM
kyhatch
27
Jan 13, 2009 04:15 PM
