Low Idle Issue Del Sol.
Old Feb 26, 2017 | 07:15 AM
xChrizcrozzx's Avatar
Icon4 Low Idle Issue Del Sol.
Straight to the point.
DEL SOL (B16A Swap)
I've recently been having some Low Idle issues randomly. Mostly Occurs when engine is Warm. To the point were engine turns off on me.
ECU is throwing a code 10. (IAT) but I dont have/see an IAT.
Looked up forms but theyre just throwing me in different directions so i thought I'd ask for help directly!
THANKS IN ADVANCE.
Video Below v v v v v v v
Old Feb 26, 2017 | 07:42 AM
mk378's Avatar
Default Re: Low Idle Issue Del Sol.
You need to have an IAT to run properly. It's either in the intake manifold or in the air pipe leading up to the throttle body.
Old Feb 26, 2017 | 08:37 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Pics of your hanging plugs.
Yes you need the IAT.
After that's in you need to reset the idle, by putting the ECU into diagnostic mode, unplugging the IACV, and then adjusting it to the proper idle speed.
Once you do that you need to do an idle learn procedure.
After that it should idle at the proper speed needed. I believe that is 750+-50 but I am not sure.
Old Feb 27, 2017 | 11:15 AM
But there is no where for the IAT to go. Do i need a new intake Manifold?
Old Feb 27, 2017 | 07:32 PM
civic402lx's Avatar
You can if u want to. Or just poke a hole in your intake pipe, insert iat, zip tie it to the intake tube. Extend the iat plug wires to reach iat sensor at the intake tube. Done.
Old Mar 2, 2017 | 01:42 PM
Actually sounds like it might work ima try that!
tgordenDELSOL
Oct 12, 2014 11:26 AM
shady3260
Jul 23, 2010 10:50 PM
fastrc2
Feb 15, 2008 12:18 PM
pdiddy
Dec 10, 2002 10:47 PM
Schmedley
Sep 13, 2002 11:07 AM
